04-13-2022 01:43 PM
04-13-2022 02:38 PM
HI @Marci You still have your old SIM? your old carrier account still active?
Do not close the old account, it will be closed when porting is completed
If you already threw away the old SIM, you need it back. Get one from a mobile store and then change sim with the old carrier so you can get the text. Yes, there is a cost but sorry, you threw away the sim too early
04-13-2022 02:35 PM
You still have your old sim I hope and didn't discard it?
04-13-2022 02:00 PM
@Marci You also need to keep your previous account active in order to transfer the number. I'll private message you the Telus porting # and they will be able send another request to your previous carrier (if active) for porting so make sure you have that SIM in your phone to respond with a yes.
Check your message box top right for the Telus number.
04-13-2022 01:59 PM - edited 04-13-2022 02:02 PM
NO, do not sign up again! You already have PM account. Keep both account active until porting is completed.
PM has to re-trigger porting. Call number I sent you and ask them to re-send porting request to your old provider.
KEEP old SIM in your phone and reply Yes within 90 minutes.
