06-19-2023 09:37 PM
I can’t seem to find where to port over my old number to a new SIM card here!
Joining Public
06-19-2023 10:08 PM
06-19-2023 10:07 PM
@UmarS203 Sure sounds like it . You. Can also test it by calling a friend and see that your old number shows up on there phone for verification
06-19-2023 10:06 PM
06-19-2023 09:51 PM
@Handy1 thanks for confirming
I don't know, either way is fine , i guess 🙂
06-19-2023 09:50 PM
@softech Yes . And I have before . But with issues that come up I find it’s best to pick temp number . Make sure services are working first then port the number . Extra step but safest step in my opinion
06-19-2023 09:49 PM
06-19-2023 09:48 PM
@Handy1 thanks for the help!
06-19-2023 09:48 PM
@softech oh okay, sounds good thanks
06-19-2023 09:47 PM
@UmarS203 If you’re just signing up first time . Review and pay for plan first , pick a temp number . Then log in and transfer your number from old provider
06-19-2023 09:47 PM - edited 06-19-2023 09:48 PM
06-19-2023 09:46 PM
06-19-2023 09:40 PM
Hey! Thanks! Just got a new SIM card from Public, so just confused if that would work for that too
06-19-2023 09:40 PM
@UmarS203 looks under the first red circle in pic transfer number tap it . And only give your old providers account number . Disregard the IMEI number it’s not needed and often causes hiccups
Change # on profile tabs
06-19-2023 09:39 PM
@UmarS203 you are existing customers, you got a new sim card and you want to tie your phone number to this new sim card?
Login to My Account using ONLY a Computer (desktop or laptop but NOT mobile deivce), go to Profile page, click on the pencil besides the sim number and follow the steps:
https://myaccount.publicmobile.ca/en/account/profile/change-sim-number
