Porting number from PM -Need to setup PIN first
BGK
Please advise how to setup a pin. PM port team asking for PIN to verify me before approving the port to Fido. Thanks.
@BGK
it is possible the link is hidden, on a browser (not app), try this direct link:
https://myaccount.publicmobile.ca/en/account/reset/pin
BGK
I don't see what you see. I've tried signing onto my account on PM website and also tried the PM app. I only see voicemail password account security info.
Dunkman
@BGK
When you access your self service account, in the profile section, you should be able to manually select your PIN.
 @BGK
login to My Account, go to Profile and you can reset PIN there
https://myaccount.publicmobile.ca/en/account/reset/pinhttps://myaccount.publicmobile.ca/en/account/reset/pin
