Porting number failed??
Bellflower31
Hello, I port my number from Koodo postpaid to Public mobile today. I received a porting message from Koodo, which I approved "yes." I then receive an email from Public Mobile that says welcome, you're all set! Also an email from Koodo (sorry to see you go) that my service is cancelled.
It's been 3 hours. I power off my phone, then insert my new public mobile SIM. However, it says unknown number in the setting... When I insert my old Koodo SIM, it has my old phone number (that I port) in my phone setting, but everything is not working since Koodo auto cancel because I approved the number port to Public mobile. What is going on?? I cannot use my new Public mobile SIM. Please help.
Bellflower31
Hi, my SIM card is now working. I can make calls and receive calls. Thanks for the link to private message the agent to help. 🙂
Bellflower31
Yes, I reply "yes" to Koodo message. Then I got an email that my Koodo service is cancelled. I also log in my old Koodo postpaid account, it's confirmed as cancelled.
hi @Bellflower31
your problem is not porting related, but the sim card was not properly setup.  Support agent can help.  Please message them
@Bellflower31  Did you reply YES with J the 90 minute window ? Ill Private message you the porting team number , they can re trigger the port request if needed . Also here’s a direct link for support should they be needed
send  a  private message   To CS_Agent
