Porting not completed
Barala
Apparently my porting was not completed when doing this phone switch over  .  Help
17 REPLIES 17
Thanks for letting me know. I was unaware of this.
@Chalupa_Batman  FYI: that little envelope for private messages is invisible on many devices; my phone and iPad for example. Messages are only visible when I tap my avatar. 😩
@Barala wrote:
 I don’t see
that message icon anywhere
@Barala , click on your avatar & you will find your private mailbox there!
You can send a private message to a CS_Agent using the link below: ->   https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
Customer Support Agents are available from:
  • Monday to Sunday: 9 AM to 10 PM EST
A CS_Agent will respond back in your Community mailbox (envelope icon) at the top right of this page to the left of your community avatar on your computer or by clicking on your avatar on your device.
Edit: @Barala , please update Us on what the CS_Agent says.
Barala
Did that for 1 hour this morning with Rogers  .  They say they did not receive port requests and need me to redo it .  That is where I am at I can’t seem to find a customer service agent to explain and help .
Truthfully...   this sounds like Rogers jerking you around. If you're able to make calls and some texts using your Public Mobile SIM card or eSIM...  then there WAS a port request and Rogers is jerking you around so you don't leave. Try calling that number again and explain to them the port was partial and you need them to contact Rogers. And then tell them if Rogers says there was no port request, ask why you can make some calls and some texts already if there was no port request. HA!
Barala
But I am able to make a call and some texts .  Is there no way to chat with customer care I did other phones no problem and this one snagged I guess .  Rogers says I need to have them send a new esim? I ready to pull the plug
Hey @Barala
Here is a little write up to help.
How to port number from “Blank” to Public Mobile
First, make sure your number can be ported by checking on this link
https://secure.koodomobile.com/checktransfereligibilityparrot/default.do
Or log in to your Public Mobile account
Then on your right side you’ll see this box. Click on Transfer Phone Number.
Then enter the number you want transfer and continue to next step
NOTE: Keep your old providers SIM card inside the phone until you get the confirmation text. Say YES. But wait just a bit longer until you no longer see your old provider's name up top. Once it’s gone, try making a call to test. If you can not make a call using your old providers SIM, the transfer has gone through.
Barala
 I don’t see
Barala
That did not work when I said transfer phone it gives me new numbers .  The ported number does show up as valid but according to rogers it was not completed on pm end .  Some services are working but it is still active with Rogers
@Barala Check your private messages up top.
The number is there to call. 🙂
Barala
Yes I answered yes in time as I did with two other phones .  Rogers says the number is not ported and still active with them .  I need to have it resent perhaps .  No one to talk to very frustrating
@Vneld wrote:
Unless it's an issue within Rogers, re-start the porting process in your PM app by going into 'My account' then clicking on 'Profile' to choose 'Transfer Phone Number'. When you get a text from Rogers asking if you want to port, text back 'yes'. If porting worked, then you'll get a text from PM instructing you to restart your phone.
I have removed the solution as the quoted post contains incorrect information.  When a port has already been requested, a Public Mobile customer cannot simply make the request in Self Serve. This would result in a error message.  A Public Mobile customer support agent needs to get involved.
Check your messages up top. That little envelope .....  you'll see it.
Vneld
Barala
Rogers says they did not complete the process yet I can use the phone for calls and some texts
Vneld
What was your last step? Have you texted 'yes' to your previous carrier?
