Porting my number
09-07-2016 02:18 PM - edited 01-04-2022 03:12 PM
Hi guys,
Unfortunely i have to leave public mobile. My number is deactivated so i can't port it. can some please activate my number for couple of days so i can port to chatr please.
thanks
Service
09-07-2016 02:30 PM
@Zed_k If you log into your self serve account does it say "suspended'? If so, you can reactivate it for 10 days to transfer your number.
09-07-2016 02:28 PM
@Chaos_Scorpio wrote:don't phones that become deactivated, the phone number goes into the recycled pile to be used in the future?
Yes & no. My understanding that once they are in the bin they are inaccessible for several months. Plus, Public Mobile does not seem to have access to any "traditional" area codes; 519, 416, 905, 613 etc.
Sometimes seems, PM can recover the number if deactivation is only a few days old. Though one cannot count on this.
09-07-2016 02:21 PM
09-07-2016 02:20 PM - edited 09-07-2016 02:20 PM
I don't think its possible to make your account active for few days. May be you can get $11 text only plan for 10 days.
If there is any other way, staff member will help you port out your number.
