11-30-2023
12:37 PM
11-30-2023
05:45 PM
computergeek541
I purchased a new plan from public mobile and had to port my number over from Telus to Public Mobile, and got an eSim for public mobile. I followed the porting instructions, received the port request from Telus and hit "yes". After this, my phone disconnected from the wifi and I never received a confirmation text from public mobile that my number was ported. My ported number shows up in my account info, and I can receive phone calls, but I can't receive any. I also tried putting my Telus SIM card back in but it is no longer connected to any signal... please help!
11-30-2023 05:54 PM
Thank you. I had also messaged them privately, but tagged them as well. I will note this for the future.
11-30-2023 05:47 PM
@Breannem11 wrote:
Tagging CS_Agent is a message here isnt' a private message. Customer supprort agents don't usually monitor the message forum. You'll need to use the link that was proivded earlier to send a private message.
11-30-2023 12:51 PM
11-30-2023 12:43 PM
Thank you all so much for the help. I will call the number 🙂
11-30-2023 12:41 PM - edited 11-30-2023 12:49 PM
I would suggest contacting a CS Agent via private message. When i ported, i just used the account number (no IMEI) and it finished in a couple hours. Just a heads up it may take a few days to hear back from customer service, ive had a message open for 2 days and still waiting.
11-30-2023 12:40 PM
check the little envelop icon on top right side of page...I sent you the number to call for port assistance.
11-30-2023 12:40 PM
Sounds like you did everything correctly so try rebooting your phone by powering off then back on and see if that helps.
If not, unfortunately it could be a provisional/backend issue with your SIM and need a CS_Agent to help you complete your porting.
I will pm you the Porting Deposit number.
