Porting in - Unable to active eSIM, error.
Azzurro32
Hi,
Ported in from Koodo. Tried two times to active eSIM, both failed. Now the only option I have when I log into the PM app on the phone is to receive a code to my phone number, but I don't receive the SMS.
I tried scanning the QR code in my welcome email as mentioned in a successful previous post,  but that opens the page to a Google search with no helpful information.
What can I do?
Thx
Hi @Azzurro32
Android steps are similar, go to the Sim Manager and you should see the Public Mobile esim there.  Make sure it is set enabled.  And on some phone like Google Pixel, you need to set it as Primary as well
And if the esim is not there, then you need to ask support for help as said earlier
Azzurro32
Thanks. Do you have steps for android?
HI @Azzurro32
you sure you scanned the correct QR for esim and didn't scanned the QR for downloading the app?
For the esim, check if it is already installed on the phone as the app should have done that for you and you don't need the QR scan.  Check the Sim Manager or Settings-> Cellular, make sure it is there and enabled (or Turn on this line is enabled) and set as Primary.  Try try Reset Network settings
if the esim really not on your phone, then ask PM support for help.  You can submit  ticket by direct message:
