Porting from shaw
mr604
I attempted to port my number from Shaw. The esim seemed to load on my phone but I received a text saying there was trouble porting number someone would reach out no on did. Shaw told me Rogers had already requested a port ( due to the merger) . I got Rogers to cancel the request, Shaw said have PM send new request.  PM system won’t let me report or send a service ticket. What do I do? Is there any customer support to speak to at PM?
2 REPLIES 2
HI @mr604
just a porting issue.  Call the porting support team and they will update you what was wrong.  Will send you the number, check your Community inbox on the top right
JRod
@mr604
I will send you the number to the porting department and they can investigate for you and re-trigger the port for you.
Check your messages here on the community.
This link will take you to your messages:
