05-06-2021 03:09 PM - edited 01-06-2022 01:59 AM
A couple of questions.
1. What is the completion time to port from Rogers to PM? Hours...Days??
2. Can you still port as part of the activation process?
3. Or just better to take an PM number and have a MOD do the port later?
05-06-2021 03:13 PM - edited 05-06-2021 03:13 PM
05-06-2021 03:34 PM
Are you saying that if you activate and get a PM number and later want to port that you can now port through the Self Service and NOT have to contact a MOD??
05-06-2021 03:36 PM
@LurganIeUk : It has been a little back and forth, but currently...yes. Right now it's only Koodo prepaid and PC Mobile that need assistance.
05-06-2021 03:38 PM
Ummm....yes its been that way for awhile now.
05-06-2021 03:47 PM
@darlicious wrote:Ummm....yes its been that way for awhile now.
Well you know...I am old....and can't keep up with all of the inconsistent changes on porting.🙁
I just wish they would fix the fluctuating referral rewards. Like 1 number on your list = $1 off and if not it needs to be noted on your account.
05-06-2021 03:57 PM
Yes I suppose when you get old you get to complain more...lol😁
