Porting from Freedom Mobile
itsawesome1234
Will porting a number from Freedom Mobile be easy. The number was originally Speakout/rogers.
RossN
If I am reading you correctly when you sign up take the number that PM gives you then make sure everything works data ,phone ,text and then port your number over, also keep your freedom account active until port is complete
geopublic
@itsawesome1234  Should be easy just login into your PM selfserve account and select change number and enter your port details. Account number, name on the account and telephone number. Once the port is complete you will get a text from PM.
Who the number originally came from makes no difference.  For Freedom, you can use the account number (and nothing else shoudl be be used) to port to Public Mobile. Be sure to include the DBC part of the account number.
@itsawesome1234  - Shouldn't be a problem at all, as long as you have the proper account information, and the account is still active with Fredom.
