04-29-2019 11:37 AM - edited 01-05-2022 04:39 AM
I would like to try the service, so I bought a SIM and selected a plan that will allow me to check the service. I am planning to port my Rogers number in about a month from the start of the service. Will that be possible?
Thank you,
Ion
04-29-2019 05:38 PM
@ion54 wrote:Thank you for the heads up. One question still remains: Can I do it after one month of using the initial issued Public Mobile phone number or there is a limited time to do it?
You can Port in a number anytime and as many times as you want your self via self serve on Publicmobile.ca
04-29-2019 01:48 PM
@ion54, the port can happen anytime, as long as the number is still active at the sending carrier.
Also, a new number can be selected from the Public Mobile list once every 30 days. Ports do not count in the 30 day limit.
04-29-2019 01:45 PM
There's no time limit , it can be done whenever you're ready and satisfied!
04-29-2019 01:35 PM
04-29-2019 12:10 PM
@ion54, when doing the port submission, make sure you enter the account number with the hyphens removed. The Rogers bill shows hyphens in the account number. Including them when entering the account number for porting purposes will result in porting failure.
04-29-2019 11:41 AM
@ion54 wrote:I would like to try the service, so I bought a SIM and selected a plan that will allow me to check the service. I am planning to port my Rogers number in about a month from the start of the service. Will that be possible?
Thank you,
Ion
No problems waiting for next month. Waiting a bit isn't such a bad idea. It gives you a chance to test drive Public Mobile before changing over completely. Good luck and welcome to Public Mobile.
04-29-2019 11:40 AM
Yes that will work! Just keep paying your Rogers account to keep your number active. When you're ready to port just go in your public mobile account and fill in the port request and it will automatically cancel your Rogers account when the port is finished. If you need a refferal number to save 10$ on your new account let me know!!
04-29-2019 11:39 AM - edited 04-29-2019 11:40 AM
Thank you,
Ion
Yes. You can port your Rogers number to PM anytime without any fee. Everything is done online at your self-serve account.
