04-24-2019 08:47 PM - edited 01-05-2022 04:35 AM
Hi,
I'm wondering if it's possible to open up a Public Mobile account, (with a new number). Then in a couple of weeks after trying out the service. Then be able to port my number I have with Rogers over to the account?
04-24-2019 09:10 PM
@Ozzi Usually there are no issues activating and porting, but suggest perusing BE PREPARED
04-24-2019 09:04 PM
@Ozzi wrote:PERFECT!
So, say I also get a referral before I port the number, that won't be an issue? I read somewhere referral's are phone number based, and not based on the account?
No issue ...the referal will stay with the 1$ credit per month with you even if you port your number from Rogers.
04-24-2019 09:02 PM
PERFECT!
04-24-2019 08:55 PM - edited 04-24-2019 08:56 PM
Just to add when porting from Rogers, make sure to remove the hyphens when entering the account number. Do not enter the account number as it appears on the bill. Including hyphens will result in porting failure.
04-24-2019 08:51 PM - edited 04-24-2019 08:52 PM
@Ozzi wrote:Hi,
YES it's the best way to port your number.
When everything is OK you can ask for the port in your self-serve account tab PLAN/OPTIONS and CHANGE MY NUMBER. You can do it by yourself.
