04-28-2023 10:55 AM
Hi,
My problem is that when I send out a text or make a call from my ported phone # (old one that I want to keep), some of my phone contacts see only my temporary phone # given by Public. I have tried multiple tickets without response. I have called the Telus, they advise that the problem might be on Public's side and that possibly Public techs need to "refresh the network". Anybody else had this problem?
Thanks,
Frustrated.
04-28-2023 11:15 AM
Try rebooting your phone first by powering off the phone then power back on.
I assumed you replied to the text with YES with the Telus SIM in your phone.
If so, it could be a provisional issue with the SIM then you need to contact a CS_Agent to look into the issue by submitting a ticket on SIMon Chatbot or private message them.
04-28-2023 11:04 AM - edited 04-28-2023 11:04 AM
It looks like porting failed or is not completed yet. As soon as you subscribe and initial porting PM will assign temporary number to you.
Contact agent for assistance:
To Contact CSA-agent there are 2 methods:
Ticket has to be opened through chatbot - https://widget.telus.tiia.ai/publicmobile/publicmobile.html
Having a ticket is preferred way to contact agent as they might respond faster then receiving personal mail.
If opening a ticket does not work very first time, contact agent directly.
- Send a private message to the CSA - agent by clicking (Ctrl+) Here
Agent’s response is usually between 15 and 120 minutes with a ticket. Private messaging might take longer.
Watch for envelope in top right corner of Community page. It will show Number of unread emails.
04-28-2023 11:01 AM
I'll give you two ways to contact them to help get the porting resolved.
First of all, check your private message mailbox by tapping the envelope icon upper right when you see a little red number in it, that'll be my message with the phone number
Secondly, you can place a support ticket as follows:
