12-08-2019 10:03 PM - edited 01-05-2022 08:26 AM
I can call out with my phone number. But once i get a call it goes to voice mail.
Joining Public
12-08-2019 10:23 PM
I would recommend submitting a ticket to get moderator help. Most mobile phone ports should be done by now. If landline or VOIP lines, it can take several days.
Click on quesiton mark on right lower corner and follow the prompts...
12-08-2019 10:20 PM
Hey thanks for the reply,
It was ported around 1pm Eastern standard Time .
I will try the ? In the bottom corner
Thanks
12-08-2019 10:06 PM
How long did you start the port? It looks like that the port has not been completed.
If more than approx 4 hours, your port is likely stuck. Then you will need to contact moderator.
Click on the question mark on the right lower corner of website to start ticketing process to contact moderator. Type: Contact moderator. Follow the prompts to submit ticket.
If less that a few hours, just continue to wait and hopefully, the port will be done soon. You can continue to use your old carrier SIM card. If it stops working, then try the PM Sim card.
12-08-2019 10:05 PM - edited 12-08-2019 10:07 PM
@JohnQ wrote:I can call out with my phone number. But once i get a call it goes to voice mail.
If you just requested the port, this is normal. Number porting is not instant. If you don't want to miss incoming phone calls, keep using your old carrier's sim card for now. If the number is coming from another wireless carrier, the number port should be completed within 2.5 hours.
