04-11-2024 08:34 AM
Hi, for work I need to authenticate by text. I ported my number yesterday.
I receive calls, but no text at all.
Luckily, IT at my job was able to get me to log into the system temporarily.
@CS_Agent can this please be fixed in a timely manner, please.
04-11-2024 10:10 AM
This was solved. It was solved by sending a ticket to cs_agent in private message. They refreshed the sim and the texts started working. Thanks to everyone.
04-11-2024 08:43 AM
The exact same thing happened to me. All it is-is just the waiting game my friend. If you have done all the necessary steps and you still can’t send sms, then it’s best to be patient, fore it will start working after everything is activated.
04-11-2024 08:42 AM
Thanks! I did both, hopefully it'll be solved sooner than later.
Appreciate the help 🙏
04-11-2024 08:39 AM - edited 04-11-2024 08:39 AM
PM has some issue with text for new subscribers:
Support can reprovision the account and fix the issue, please engage them by opening a ticket:
