11-12-2020 12:00 PM - edited 01-05-2022 05:25 PM
Hi,
I ported from post paid fido plan after paying my bill. I just received a mail from fido regarding new bill for next billing cycle. I called fido's customer care, they said that my number is not port out to public. It is still with fido.
But now I am really confused because I am using Public sim card and I can receive calls etc.
Can sombody please help me figure it out?
11-12-2020 12:38 PM
Do you get any incoming calls or text messages?
If yes, your port from Fido was completed. As soon as Fido released your number to PM, your Fido account will be canceled. Fido cannot continue to charge you without a phone number attached to your account.
If no. Fido has not released your number to PM yet. This may be why Fido is continue to charge you as your Fido SIM card is still working.
PM setup you Fido number right away for you to call out, send text and data as soon as you requested porting your number to PM.(Stage 1)
Porting a mobile number will take about couple of hours to couple days depending how quickly Fido release your number to PM (Stage 2).
Mobile providers have a new Port Fraud Prevention procedure in place now. They will send you a text message to fonfirm that you want to port your number out. If you do not confirm with a "yes", porting will stop.
Did you receive a Fido text message to ask you to confirm that you want to port your number out?
FYI - Number porting is a 2 stage process:
Stage 1. After submitted your porting request, PM set up your old number on your PM account. Login to your account. Select the [Plan and Add-Ons] tab. Is your old number showing on the [Plan and Add-Ons] page?
If yes, PM has done its work to setup your old number for you to call out, send text and data.
If no, you should create a support ticket for moderator to investigate. Moderator wait time is from couple of hours to couple of days.
Stage 2. Now, you are waiting for your old provider to release your number to PM. Not until your old provider release your number, all the incoming calls and texts will continue to go to your old provider. You can continue to use the old provider SIM card until it stops working which is the indication that your number was released to PM.
11-12-2020 12:16 PM
Does your PM SIM work for:
Data
inbound and out bound calls
inbound and out bound texts
If yes the number is fully ported over.
Does your FIDO SIM work for any portion of:
Data
If yes the number is NOT fully ported over.
I am thinking there is a time lapse of your account records at FIDO??
11-12-2020 12:10 PM
If you can check your Fido account to find out if it is still active. When porting is completed then your Fido account should be closed automatically.
To complete your port-in request, please open our chatbot via this link and type in “port request” to be put in touch with a Moderator.
11-12-2020 12:06 PM - edited 11-12-2020 12:14 PM
@jon1609 wrote:Hi,
If your phone is working satisfactorily on the PM network...just don't pay any more Fido charges. You don't have a cc there do you ?
Likely just a billing department oversight at Fido.
EDIT...cc meaning a credit card or other payment card.
11-12-2020 12:05 PM
@jon1609 wrote:Hi,
Here’s how to contact the Moderator Team (Public Mobile representative) for assistance:
