09-21-2023
09:14 PM
09-21-2023
09:47 PM
computergeek541
I tried paying from the website, but, it went to payment page instead of asking to get the number to be ported and account number, and got it activated
Need help guys
09-22-2023 10:56 AM
Oh, I see. He had the sim for years now, it would be a loss to change it. I guess then we do not have another option, other than keeping on paying Quebec taxes in BC. Thanks for the info though!
09-22-2023 07:47 AM - edited 09-22-2023 07:48 AM
The taxes are based on the phone number. The number would have to be changed (would lose the old phone number) or vouchers can be purchased at B.C. stores that carry them for future payments.
09-22-2023 01:21 AM
@computergeek541 what do you think of this?
The number which the friend has taken from the other company to PM, the sim is from Quebec (number) so, the tax which they are charging are QST, so, tax is quite high. Any solutions for it? Considering we're living in BC, and tax is being charged for Quebec
09-22-2023 01:20 AM
The sim got activated at least within 30 mins and that is the good part! Hope my friend gets to make the best use of it, before I do. As I did not port today, my friend did!
09-21-2023 10:03 PM
Need some ideas!
09-21-2023 09:54 PM
@Shubh2023 wrote:Followed the steps, which you mentioned. The old sim is still in the phone & I will wait for 30 mins to see, if I lose network on the former sim, then, will put in the PM sim. Thanks for the advice, I will follow it!
Ideally, both SIM cards would be in a compatible phone. If there is any issue with the number porting, Public Mobile will inform you by text message, and you'll only see that text message if your Public Mobile SIM card is being used. Also, any text messages sent from other Telus, Koodo, and Pubilc Mobile customers will only go to your Public Mobile service. Sometimes, incoming phone calls from Telus, Koodo, and Public customers only go to the Public Mobile servcie. However, other incoming calls and incoming text messages will only go to the service of your old carrier (and you also wouldn't receive the text message from the old carrier that you're required to respond to if you're only using the Public Mobile SIM card).
09-21-2023 09:48 PM - edited 09-21-2023 09:48 PM
09-21-2023 09:41 PM
HI @Shubh2023
now, you should be able to make outbound calls and just not able to receive inbound calls
To complete port, put your old carrier sim in a phone, wait for a text from old carrier and reply Yes within 90 mins. After you replied Yes, then you can go back to PM sim, make sure it can receive inbound call. probably need to reboot couple times until you got inbound calls
09-21-2023 09:26 PM
Thanks!
Just completed the procedure, downloaded the app as well! It worked just fine! Will just wait for an hour maybe, to get it ported
Thanks again 😊
09-21-2023 09:18 PM
Once you're signed up, you'll get a temporary number. Don't worry about it. Once you're signed up, follow this and port over with ease. Just remember, your number you're porting MUST be active. If it's not, then it won't work.
How to port number from “Blank” to Public Mobile
First, make sure your number can be ported by checking on this link
https://secure.koodomobile.com/checktransfereligibilityparrot/default.do
Or log in to your Public Mobile account
Then on your right side you’ll see this box. Click on Transfer Phone Number.
Then enter the number you want transfer and continue to next step
NOTE: Keep your old providers SIM card inside the phone until you get the confirmation text. Say YES. But wait just a bit longer until you no longer see your old provider's name up top. Once it’s gone, try making a call to test. If you can not make a call using your old providers SIM, the transfer has gone through.
09-21-2023 09:15 PM
HI @Shubh2023
it is normal. It is payment page first, then you need the app to complete the activation for phone number/or porting
please download the app on your phone and continue using the app instead. For porting, remember to provide account number of your old carrier instead of IMEI, it is less trouble using account number
