Poor call quality
andrew20
Hi,
I am a long time PM user and have had great service until a couple of days ago.
When I am making a call the other person reports that my voice sounds distorted and robotic, they can not understand me. I can hear the other person clearly on my end. I have attempted calling a few different people, sometimes it happens immediately, other times the issue starts a few minutes into our conversation.
I have been using a Google Pixel 6 with no issues for almost a year.
I did receive the message that I have been moved to VoLTE this week, could this be related? Are there setting I need to change on my phone?
Any other suggestions or help are appreciated.
11 REPLIES 11
@GregStarla yes VoLTE toggle is hidden by Telus/PM on iPhone and you cannot just turn VoLTE off and keep data on LTE.  Your only option left is to  keep the OS and Carrre profile both up to date and hope one of the new one fixes the issue.  But do you notice the voice sound better in different area?
GregStarla
I am using iPhone 11.
I really don’t want to put my phone, even if possible, back to 3G as I’m paying for 4G plan.
@GregStarla you cannot  turn off VoTE, are you using iPhone? I guess you don't want to change data to 3Gbasbwell to avoid VoTE?
GregStarla
I have the exact same issue. I added a new line and it was automatically placed on VoLTE. Calls are always distorted, dropping or the person can’t hear me. I can’t seem to be able to force my service to 3G nor disable VoLTE. Very irritating. My old service account has degraded too since moving to 4G plan.
Mlven78
I've been having the same issue.  3g the calls work completely fine volte dropped calls or can't hear the caller.  Support has been unable to help.  This has been going on for months so leaving volte for a few weeks and coming back has definitely not been the solution
@andrew20   yes, if you are using 3G , the network icon will shows H or H+
You can keep it like this for now, and change it back to Automatic in a week or two and check if you have VoLTE enabled yet and see if you can use VoLTE
andrew20
@softech
Thank you, changing the preferred network type to 3G seems to have significantly improved the call quality.
When I make calls the network icons do drop to H or H+.
@andrew20 wrote:
@Dunkman
It is happening in various locations, but the majority of my calling is from home. I am in a rural location and at times my data can be slow, but calling has always been good.
My phone is up to date and I have tried rebooting it.
I have had my SIM card for almost 7 years now, I've read that might cause issues, is it worth it to try replacing it?
@andrew20
Should not be a SIM card issue.
See whether you are on VoLTE service
https://www.publicmobile.ca/en/ab/get-help/articles/volte
@andrew20
do you know if VoLTE is working on your profile/phone?
Can you try to enable VoLTE on your Pixel:
       At Settings->Network and Internet->Internet, click on the settings icon besides SIM 1, turn on 4G calling there
When you make calls, check if the network icons stay at 4G or LTE or does not drop to 3G (or H+)
Or you can test to use ONLY 3G network.  Change your preferred network to 3G
   Settings->network and Internet, click on the settings icon besides SIM 1, change the Preferred network type there
See if you get better calls with 3G network selected
andrew20
@Dunkman
Dunkman
@andrew20
It might be related to VoLTE implementation.  VoLTE should make calling more better.
Is the calling issues happen at a specific location or various locations?
Checked online and Google pixel 6 got an update in 2021 which turn on automatically VoLTE if available.  No option to turn off or on.
Try rebooting your phone.
