01-19-2023 07:41 PM
So what is better the news point system or the old program?
Anybody looked into it?
01-20-2023 12:28 PM
Quick answer.
Don’t do it!
01-20-2023 03:17 AM
@AndyPM if i were you i would stay in the OLD program because the auto pay $2.00 is no longer vaild also you save some $$$ as well on your bill but once you switch over there are no turn back period.
cheers 🙂
01-19-2023 09:24 PM
If you use the example of a customer with the $40 plan that is the $2 autopay reward break even point then the main difference between the two programs is the loyalty reward vs anniversary points. Community (give back) and referral rewards/points are earned in the same way with the same value.
You get the point.....? 🤑$$😁
01-19-2023 08:12 PM - edited 01-19-2023 08:13 PM
for some with higher value plans, Points might be worthwhile choice.....Naawww, just kidding.
Friends don't let friend opt out of Rewards in favour of points.
...but if you must...
https://www.publicmobile.ca/en/bc/get-help/articles/Joining-Public-Points
01-19-2023 07:53 PM
And candy is dandy 😉
01-19-2023 07:50 PM
Stay with the old yeh new is not worthy of a change
01-19-2023 07:48 PM
Handy Andy 😉
01-19-2023 07:46 PM
Lotsa people looked at this @AndyPM .
My vote, Old Rewards program is better! Stay in it if you can.
01-19-2023 07:45 PM
@AndyPM stay on old rewards once you go to points there’s no way back to rewards it’s a one way street and not worth it
01-19-2023 07:44 PM
Definitely the OLD program.
If you joined here before January 25, 2022, and are still on the OLD rewards system, DON'T switch to Public Points before making an informed decision.
The largest difference is the Loyalty program.
01-19-2023 07:42 PM
Ya think? Don't switch!
