07-14-2023 11:06 PM
Hi there, friend lost SIM in a phone and wants to replace it - however the solution to replace SIM is to log into account. Can't log into account without SIM.
How can my friend log into their account/replace SIM if the phone is not working?
Thanks
07-15-2023 12:20 AM
Thanks for reaching out. The following workaround worked. Appreciate you responding.
Try these workarounds, it could bypass the SMS in linking My Account with EverSafe ID
07-15-2023 12:16 AM
Thanks very much - work around worked. Dave
07-14-2023 11:09 PM
Have them tap resend a few times and you should get option to send to email instead . If that doesn’t work please submit ticket with support to help
message support directly
while your already here and logged in the community you can send a private message To CS_Agents click
VVVVV Link below VVVVV
07-14-2023 11:08 PM
PM just changed to a new EverSafe login system and you need to complete the setup on this new system.
Have you login to My Account since EverSafe was introduced?
If you have already created an EverSafe id, you can ask the code to send to email instead
On the screen it is expecting you to enter the code, click Resend code and then choose Send email
If you have not created an EverSafe id yet, you won't be able complete the part to link your My Account with the EverSafe ID, that needs a working phone with a working PM sim using SMS. (Sending the code to email would not be a choice until EverSafe id is fully setup)
If none of those workarounds helps, please open ticket with support by direct message here:
