Plan
car62
I see that the same plan I have now is on $34 but gives me 10 go off data just wondering if we be safe to get with out public mobile cancelling anything on me I no I will have to go to there point system
1 REPLY 1
All customers will be switched to the points system soon, but that won't be caused by any plan change.  As for the $34 plan that includes 50GB of data, you're free to switch to it.  I would suggest pre-scheduling the change so that it happens at renewal time to avoid losing what you've already paid for your current plan.
