Plan upgrade
07-26-2019 07:48 PM - edited 01-05-2022 08:26 AM
my plan just renewed but I was wondering if there's a 'grace' period to upgrade the plan... I wanted to switch to the $60 promo with US roaming data
Service
07-26-2019 08:44 PM
@Osaga just going to state WHT I would do in your situation
1) futuredate the plan change
2) add funds to your account equal to the difference in plan costs
3) message moderator_team and explain what happened and what you would like. In the past they have been pretty good granting these type of requests when done within a day or two
4) be patient it might take time to get a reply
07-26-2019 08:34 PM - edited 07-26-2019 08:35 PM
If you're planning on doing some travel to USA, then have a look at the Public Mobile 10 Day US Roaming Add-on options that are also currently available...
Unlimited Talk, International Text and 250MB Data for just $20 for 10 days.
Unlimited Talk and International Text for just $15 for 10 days.
Unlimited Talk for just $8 for 10 days.
Unlimited International Text for just $8 for 10 days.
250MB Data for $10, 500MB Data for $15 and 1GB Data for $20 for 10 days.
07-26-2019 08:05 PM
@Osaga wrote:Thanks... I was hoping there was grace period... I guess there's a downside to auto pay
Haha. Yea. It does what it is supposed to do when sometimes we don't want it to. I've been there, i feel your pain.
07-26-2019 08:00 PM
@Osaga wrote:my plan just renewed but I was wondering if there's a 'grace' period to upgrade the plan... I wanted to switch to the $60 promo with US roaming data
@Osaga No there isn't but you can setup the plan change and chose for it to take effect on your next renewal.
AutoPay reduces your bill by $2 every 30 days! That a good thing. 🙂
07-26-2019 07:58 PM
Generally, there is no refunds. You can set your plan change at your next renewal.
Or you could try to contact moderator, so see whether thay can change it earlier, but there is no guarantees. Maybe top up your account to make up the difference. YMMV.
Send a private message to moderator through the following link :
07-26-2019 07:55 PM
07-26-2019 07:50 PM
@Osaga hi no there is not if you change your plan now you will forfeit what you paid for it
