01-13-2023 07:25 AM
I made a request to switch from my old plan ($120 12gb 90 days) in November to the new plan ($40 15gb 30 days) plan and requested switching upon renewal. However I noticed today, the switch didn't happen and my old plan's valid period got shifted and shows will end in February instead of today. Can you please take a look at my account to see why that's the case?
01-13-2023 09:32 AM
@rogermobile @Happy you got it sorted out
01-13-2023 09:30 AM
Thanks everyone for your help. Yeah they really need to fix the cache timeouts and refresh for sure!!
01-13-2023 07:49 AM - edited 01-13-2023 07:50 AM
Public Mobile's self-serve site has terrible caching issues - which means it tends to display outdated information.
The best way to avoid this is to open an incognito or private tab on your web browser, then log into self-serve.
If then you notice the amount paid was your old 120-day plan, (you also may want to confirm this via your payment card transactions) you can either contact a customer support agent to have them switch it out as you had requested, or schedule a plan change for the next cycle.
01-13-2023 07:48 AM
@rogermobile it should be just a browser cache issue and you are reading old cached page
Try to login My Account again using Incognito Mode and you should see the correct plan.
In fact, always use Incognito mode to login My Account to avoid confusion
01-13-2023 07:26 AM
Try again incognito mode/private mode or simply try refreshing the page on the yellow circle while signed in to public mobile
Refresh page. ^^^
