Plan not working.
Lilbriwn870
I just got the 40$ plan, I've been a pm member for a while now, I never had this problem but my plan will not work. My old plan expired yesterday and I didn't get around to putting money into my account until today and when I selected my plan and renewed it the plan won't work. Any help would be awesome. Thanks in advance.
18 REPLIES 18
Lilbriwn870
@Lporter add 1-2$ to your account .that may fix it too. Lost/stolen trick works sometimes too
@Lporter
You could try the following
- rebooting your phone
- the lost/stolen phone trick
https://productioncommunity.publicmobile.ca/t5/Paying-for-your-service/SOLUTION-My-plan-has-enough-f...
- try his SIM card in your phone to determine if it is a hardware issue versus service issue
If that does not work, you may need to contact moderator for help.
Send a private message to moderator through the following link :
Lporter
I am just learning how to use this community board concept, bare with the newbie.
We got a brand new phone number. Activated today.
He can receive and send text.
He can receive calls.
But cannot make outgoing calls
 ...if you start a whole new thread, you'll have a far better chance to get resolution.
@Lporter
You might in the future start your own thread/topic to get better visibility.
Did your husband port a number over?  Or activate a new PM phone number?  How long has it been since activation of account?  Can he receive calls?  text? data?  More details would be helpful...
Lporter
I have just set up both my husband and I on public mobile.
However my husband's outgoing calls will not work.
Please advise a way to resolve the issue
@Lilbriwn870 wrote:
I did the lost phone trick
Glad you got it sorted.
If either response to your particular request leads to the resolution of your issue , please help other community members by marking that post as the solution. Thank You
Lilbriwn870
@Lilbriwn870 wrote:
It's working now. Thabk you alot everyone
Do you know what fixed it? Sometimes it is nothing more than time.
Lilbriwn870
@Lilbriwn870 wrote:
I did the lost phone trick, I can call now but still no data or texting.
Another account reset option that many found to work is to add $1 funds to your account.
Lilbriwn870
Not sure if you've attempted restarting your phone or not.  Give that a shot.
Also, as mentioned above, report the phone LOST in SelfServe, wait about 5 or 10 minutes, the report it FOUND in the same place.
Lilbriwn870
About and hour or so now.
@Lilbriwn870
Try the lost/stolen phone trick.  In your self service account, report your phone lost/stolen.  Logout.  Login back in a few minutes.  Report your phone found.  Re-boot your phone.
This seems to re-boot/re-set your SIM and plan.
mkharban
Is the service bar in the screenshot that of public mobile's? I have had instances in the past where it would take some time for the renewal to take effect (like 1-2 hours). How long has it been since you've renewed it?
Lilbriwn870
Says it's active but not working. Can't call, text nor use my data @stonechucker
stonechucker
@Lilbriwn870, when you say it won't work, is it the phone that's not working or the status change to 'Active' that isn't working?
