Plan is not active
01-18-2024 04:57 PM
01-18-2024 05:15 PM
@Alicia06 wrote:My plan is active but I have reached my data limit.. I have bonus data is that why it's not working?
Everything is working except calls and text messages
Are you on a 5G plan? With 5G speed plans, once your reach your limit, you will get unlimited throttled speed data. At the present time, bonus data add ons are not compatible with the 5 G plans since customers are throttled data.
Did you try to reboot? Network reset of phone?
You could also try the SIM card in another working phone. That will help determine whether hardware issue versus PM service problem.
01-18-2024 05:14 PM
Using plan vs bonus or added data would have no impact on your ability to call or text.
It's odd that your DATA works, but not calling or texting. To be certain, you've tried both outgoing and incoming calls and texts. And for texts, you mean SMS and not iMessage, correct?
01-18-2024 05:11 PM
Please dial 611 from the device with the Public Mobile SIM card in it.
What messaging is heard when you do this?
You might also want to try the SIM card in another device to ensure the issue is not device-related. While you're at it, also try the other person's SIM card in YOUR device to see if all their services works in it.
Doing this won't cause any issues, but it will troubleshoot the issue.
01-18-2024 05:10 PM
01-18-2024 05:01 PM
What does your My account show? Active versus suspended status?
If account is active status, you can try to reboot phone. Network reset of phone (note: this will erase any saved Wifi password setting)
