01-18-2024 02:40 PM - last edited on 01-18-2024 05:34 PM by computergeek541
Please send me the authorization to port a number from 7-11 Speakout to Public Mobile. I missed the 90-minute window by inserting the new PM sim card too early. Thank you
01-18-2024 05:23 PM
@mabelchan How long ago did you port out from 7-11? When I ported out in 2022, 7-11 didn't send out an acknowledgement to port the number, so don't worry about that. Sounds like they confirmed that when you called them by them releasing the number to PM. It took my port about 6hrs to complete so if it hasn't been at least that long, I'd just wait. I posted about my 7-11 port experience here in case it might help. Success Porting from 7-11 Speakout to PM - Community (publicmobile.ca)
01-18-2024 03:57 PM
You to reply to the text with the 7-11 SIM in your phone to complete the porting. The old SIM will continue to work for about 2 hours until porting is done. Then power off your phone and swap the SIM.
01-18-2024 03:13 PM
I called 7-11 Speakout and was told that the number was released to Public Mobile. Can Public Mobile made my number active?
01-18-2024 02:42 PM
HI @mabelchan
7-11 is different, they might not send you the text to approve. Please call 7-11 helkpdesk and see if they receive the porting request
For PM side You can call Public Mobile porting team to provide the correct Info and get status update. I will send you the porting team number. Please check your Community inbox for my message
