09-16-2022 01:37 PM
Hello
I received a text that I've used 75% of my plan data but I've only 1 week into this current cycle. It's possible I had my wifi off too much, but it's odd. When I check the status on the public mobile site it references my old plan that I changed 2 months ago, not my current plan which is faster and with an extra gig per month.
It shows I used 75% of what I used to have but I increased my gigs. Help!
09-16-2022 03:26 PM
open a ticket with PM CS_Agent. at : https://publicmobile.ca/chatbot.
type: Contact Us and Other
Finally Click here to submit a ticket
If you have error submitting a ticket, send a private message to the CS_Agent: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
check inbox(top right corner envelope icon) for response from CS_Agent.
09-16-2022 02:21 PM - edited 09-16-2022 02:22 PM
@dust2dust Yes private mode would suffice for all. Plus FF uses private too. I just got into the habit of using incognito but might switch to private too, lol..
@computergeek541 thanks for the clarification, haven't used Edge, so wasn't aware of that.
09-16-2022 02:21 PM
@dust2dust wrote:@dabr- I think I'll switch my wording to "private" mode. Incognito is bit much to type and is only used in Chrome. Samsung says Secret. Private seems generic enough.
HI @dust2dust but maybe more people will appreciate your "private" mode. Safari calls it Private Window. 🙂
Yes, can't they all agree on one term. Everyone try to come up with fancy names of their own
09-16-2022 02:18 PM
09-16-2022 02:13 PM
@dabr wrote:
@dust2dust wrote:@Padungsak- You mean you clicked on those lower refresh icons? The other option is to use incognito or whatever it's called in apple-speak in the browser.
I've seen the term "InPrivate" mode mentioned often by another user, could be what apple uses as I believe that user has an apple device.
InPrivate is the term that Microsoft uses for Edge.
09-16-2022 02:10 PM
09-16-2022 02:03 PM
09-16-2022 02:01 PM
This happened to me on my iPad, and it confused me as I was receiving notifications that I was at 75 and 95% yet when I logged on to my account it showed no usage. And hitting the refresh button didn’t work. So, i logged on to my PC and went to my account..my current plan and usage were correct and current, whereas my iPad showed my old plan and no usage.
09-16-2022 01:54 PM
09-16-2022 01:40 PM
Click the little spinner refresh icons lower down to see if updated data shows up. The site is terrible at caching.
