Plan change
Jamiesgirl2017
I changed my plan and have waited the 36 hours . I still have no service !!!
@Jamiesgirl2017
Another "trick" that you can try is to manually load $1 into your account.  That sometimes restart/resets your plan.
You should probably put your request for moderator assistance if you have not already.  Expect 2-3 day wait.
Send a private message to moderator through the following link :
Please include in the private message your phone number, your account number and PIN code.
Effort
Is your account currently active?
Jamiesgirl2017
It did not work.
mimmo
Try enabling the lost stolen feature in selfserve for 5 minutes then clicking found phone. Seems to reset accounts.
