Plan change error
Jimmyb1
I chose the 15Gb at 4G a month ago and plan should be in effect. Shows in my payment that the plan change was made and paid for. It’s been a month and now it shows that my plan is back to 5Gb at 3G. Is there an error?
Rasto
I just came here to search for the same issue!  I ended up having to "Clear site data" (in the Chrome browser developer tools).
Hope that helps @Jimmyb1
HI @Jimmyb1
could be just cache problem and you are reading old info
try to clear cache and restart browser
or try using Private or Incognito mode to check My Account
Yummy
If you are charged new plan cost then new plan should be in effect.
Public Mobile has web page cache issue so you might be looking at obsolete status. Try using different browser. Try Incognito mode. Clear browser’s cache. Try forced refresh. Use computer and not phone to log in. Click on little spinner refresh icons lower down.
Metal1967
@Jimmyb1  Cached page .. try using incognito to check
walker1
@Jimmyb1 Login to your account using a different browser in incognito mode. Your probably looking at old cached information.
