27GB $40 plan 12 months is that a typo?
torontokris
Appears they combined the 15GB with the promo code (they did not work together before)
Is that a typo? Maybe should be 5Gb + 12
OR just the 15GB (no 12 bonus) not both combined
https://publicmobile.ca/en/on/plans#4G
Even the link says 5G (link doesn't work for me)
https://publicmobile.ca/en/on/plans/5GB-4Gspeed
7 REPLIES 7
thanks @J_PM for confirming
We need more good plans like these!!!
Still limited offer at this time. End date is still open ended.
HI @J_PM
is $40 for 15 GB and $45 for 20GB still a limited time offer?  is there any end date to it?
J_PM
Public Mobile
Public Mobile
@torontokris This is a typo. Should be $40/5GB. Our teams are working to correct it🛠.
torontokris
Showing as $60 here on this link so guessing a typo
https://www.publicmobile.ca/en/on/plans/15GB-4Gspeed
Based on past infromation, this appears to be an error, but I'll try to see what I can find out.  In general, pricing errors do not need to be honored it as long as the error is an honest mistake and as long as it is corrected.  Should they honor it? I would say yes, but that's a decision that Public Mobile would need to make.
dust2dust
The 12 month 12gb code does not work on the 15gb plan or the 20gb plan.
The 20 off code works on the 20gb plan.
Typos abound. The yoozh.
Adding - but hey false advertising and all that. Take a screenshot and hold them to it.
