11-26-2022 08:55 AM
Hi, I scheduled a plan change to the $40 15gb plan and it doesn’t appear in my account, my credit card was charged for the $40 minus my bonuses. Help would be greatly appreciated.
thanks,
11-26-2022 11:05 PM
you can call 611 and it will tell you how much data your account has. this will also include add-on data. dial 611>3, enter your 4 digit pin
11-26-2022 10:32 PM
Mine is doing the same thing. I just posted the same issue
11-26-2022 05:40 PM - edited 11-26-2022 05:42 PM
when it's your renewal date you have to wait till the account is finished renewing(usually around noon). then the website updates. also just click the refresh button for updated information. the website doesn't automatically generate the updated info
11-26-2022 12:53 PM
All got sorted out, CS_Agent was able to help me change it to the 15gb plan, could’ve been me, could’ve been the system, bottom line it was sorted. Thanks to everyone for you help!!!
11-26-2022 12:42 PM
If incognito doesn’t work try a different device or browser. I just tried a different browser and it shows the 15GB plan now.
11-26-2022 09:28 AM
Hi, will try chatbot, I was aware of the 5gb $40 plan and the 15gb $40 plan, the plan just changed today, hope it can be resolved. Thanks
11-26-2022 09:26 AM
@Teeee51 maybe you picked the wrong plan? there are always two $40 plans there
If the plan supposed to be changed today or last 2 days, maybe PM support can help to switch back the plan for you. Please open a ticket with them:
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
11-26-2022 09:24 AM
Did all of the above, still shows 5gb plan in incognito, should to be 15gb plan.
11-26-2022 09:13 AM
Public Mobile has web page cache issue so you might be looking at obsolete status. Try using different browser. Try Incognito mode. Clear browser’s cache. Try forced refresh. Use computer and not phone to log in.
11-26-2022 09:13 AM
Check on the right side of the plan page. The extra data might be displayed on the right side, it is for me.
11-26-2022 09:11 AM
Just tried in incognito, will try again
11-26-2022 09:08 AM
@Teeee51 did you try using incognito mode to check?
The site has some cache issue and you might be reading old cached page if you don't use Incognito mode to check. Please login again using Incognito mode to check once more
11-26-2022 09:04 AM
Looks like it updated, but showing 5gb plan? I’m sure the change was for the 15gb plan, price being the same I definitely would opt for 15gb.
11-26-2022 08:57 AM
@Teeee51 Check again in incognito mode on your browser.. cached page issue here..
