01-21-2016 10:28 AM - edited 01-04-2022 12:48 PM
08-03-2017 01:33 PM
@grkscrapper wrote:what if your phone is lost and don't have a phone to replace it with?
@grkscrapper, you have replied to a thread that is a year old. You are better off to start a new thread. But to answer your question if you have lost your phone, login to your self serve. On the right hand side under Profile or using the Plan and Addon tab you will see a tab that says lost or stolen phone. You can go in there and suspend your service until you get a new phone or find yours.
08-03-2017 01:15 PM
01-21-2016 11:37 AM
You took the words out of my mouth! That's what I was essentially going to say if I were asked when to port if one were near plan expiry.
Bravo to you!
Cheers.
01-21-2016 11:25 AM
That's what I figured, but just wanted to make sure. I guess the tip would be for users to switch your plan renewal to a 10 day plan in order to keep your phone number, until a port is complete.
01-21-2016 11:05 AM - edited 01-21-2016 11:18 AM
Hi @yads,
To port a number from PM, the account must be active and in good standing, which excludes "Status: Expired" which is displayed on plan expiration.
In other words, you must port the number before the plan expires.
FYI.
01-21-2016 11:02 AM
Curious, when you fail to renew your plan, do you need to port your number before your plan ends or do you simply need to do it before the 91st day after your plan ends.
01-21-2016 10:39 AM - edited 01-21-2016 11:01 AM
Hi,
Since your plan was prepaid, there is no cancellation involved, to be technically correct.
Just let it reach its expiry date, and then don't renew it. Remove your credit card from autopay.
On the 91st day of your account being in expired status, the account and SIM card will be permanently deactivated, and your PM number lost forever. If you plan to port the number, your account can't be in expired status. Lastly, on the above 91st day, your account will be deleted from the system.
Should you wish to use PM's services again, you will need to start over as a new customer, including ordering a SIM card.
Also, there is neither a full nor partial refund of the plan if it is the plan that you chose.
I hope that this has answered your question.
