Plan Not Working
06-29-2017 12:50 PM - edited 01-05-2022 02:18 AM
Service
06-29-2017 01:07 PM
@ninizinzu select 6GB
See points 2 and 3 of this post: https://productioncommunity.publicmobile.ca/t5/Announcements/Update-Competitive-Response-Limited-Tim...
Once activated, your data plan will be upgraded from 6GB per 90 days to 12GB per 90 days within 72 hours.
06-29-2017 01:02 PM - edited 06-29-2017 01:06 PM
https://productioncommunity.publicmobile.ca/t5/Plans-Add-Ons/Solution-for-wrong-plan-added/m-p/16329...
06-29-2017 01:01 PM - edited 06-29-2017 01:01 PM
06-29-2017 12:59 PM
With ongoing promo, do I select 6GB data or 12GB? The price does not seem to make sense when I select 12GB.
06-29-2017 12:57 PM
06-29-2017 12:51 PM - edited 06-29-2017 12:52 PM
Send a msg to mod they will look after you soon hopefully. Be patience since mod have lots of work load on them but they will resolve your issue.
Contact any moderator by private message to help you with the process.
In your private message the following info
* PM account email address
* PM phone number
* PM SIM card number
* Detailed explanation
Here is the link for how to contact moderators http://productioncommunity.publicmobile.ca/t5/Knowledge-Base/Updiated-Contacting-our-Community-Moder...
What you do click on link the webpage will open. You will see a mod team click on any name then scroll down all the way and click on send a private msg then explain your problem
Thanks"
