Plan Change
Jeanster
I just changed my plan last night (less than 24 hours ago) I made a mistake and I hit the change now instead of at renewal.  As you can see from my payments I just made a payment of $ 25.00 on my old plan on February 25 , 2024,. Would it be possible to change it to the next renewal and refund me the amount I paid last night ? Thank You
Jeanster
Okay, Thanks
Jeanster
Okay, Thank You
Dunkman
@Jeanster
Since Public mobile is prepaid, Public mobile does not pro-rate plans or refunds.  When you clicked on change immediately, there was a warning that you would be charged immediately.
Unfortunately, nothing really can be done.
Chalupa_Batman
Hello @Jeanster
We are all customers here like you. I'm sure if you hit the change NOW button, there is nothing you can do. You can share your concerns with a CS Agent here at this link.
