03-29-2024 02:33 PM
03-29-2024 04:16 PM
Awesome thanks, the link worked so the pin is set up, but the PIN option is still not appearing under the account. Perhaps it might take some time for the changes to reflect.
03-29-2024 03:51 PM
use this direct link to update the PIN
https://myaccount.publicmobile.ca/en/account/reset/pin
after you update it, the PIn option will appear on My Account 's profile page
03-29-2024 03:46 PM
Yeah this is occurring on all browsers I have, even the mobile app doesn't have the Pin option either.
03-29-2024 03:44 PM
The website can be finicky. Might want to try to login by first clearing cache, incognito mode or a different web browser. Or even try a different device.
03-29-2024 03:43 PM
Sorry, to clarify I have no issues with my account but when I submitted a request for support they weren't able to validate my pin (which again I don't remember if I set one up) So I had to validate my account in a different way.
Based on the photos provided, I don't see the option to set up a Pin, or maybe It's buried somewhere else within the menu that I'm missing.
03-29-2024 03:26 PM
@Sushi_Combo You just have to log in to your account and set one up as suggested, or is your problem that you are unable to log in?
03-29-2024 03:23 PM
I don't see this Pin Password under my profile, when contacting support they asked for it but there was no way for me to provide since I don't remember having it set up during my account creation.
03-29-2024 03:15 PM
I assume that it is your PIN for your self service account. You choose one when you first activated your account. If you forgot it, you can reset and choose another PIN.
From the website, under profile section
03-29-2024 02:41 PM
