Pin change
Bellzz
I need to change my pin
@Bellzz  yes, the PIN update page is hard to find now
Please login My Account using the browser first.   After logged in, paste this  link to access the PIN update page:
https://myaccount.publicmobile.ca/en/account/reset/pin
@Bellzz
if you're unable to change it using either app or web...click the orange chat bubble on lower right side of page (on the web version)....then start the process to contact Customer Support for their help.
Bellzz
It’s not coming up for me, not that easy
hairbag1
@Bellzz
Easy… log in to your account and tap the Account tab at the bottom… then scroll to find Reset Pin.. Make the change and save.
edt
