04-22-2021 10:52 AM - edited 01-06-2022 02:35 AM
Hello
Does anyone know why I keep getting a failed to send message when I try to send a picture to non iPhone people? Sometimes they get the picture and sometimes they don't. This just started about 2 weeks ago...
05-06-2021 02:32 PM
@Sharon4 wrote:So, I'm not sure what you mean by that last reply... I have not got those options to choose. I have an iPhone 7 Plus.
I am still having the failed to send issue with my picture texts...Something strange is happening with my overall service in my community. It's rather annoying!
@Sharon4 Couple of thoughts:
05-06-2021 02:03 PM
Along with @AE_Collector ..... @LurganIeUk and @Luddite can offer some advice on your issue.
05-06-2021 12:45 PM
04-22-2021 06:54 PM
Hi @Sharon4 ,
Are your Chat Features enabled? If so, turn them off.
04-22-2021 06:15 PM
MMS requires data to be on but it does not consume your data. MMS is sent thru a completely different server than the server that your mobile data is metered on.
04-22-2021 06:10 PM
I have an Android... it need data to be on unless there is a trick to do it over WiFi
04-22-2021 06:07 PM
@Meow : Yes it really should kinda have a disclaimer. Your phone may very well do a bunch of other sync-ing when it sees the internet. But MMS doesn't consume data. iMessage will though unless you set it up properly.
04-22-2021 06:03 PM
@AE_Collector wrote:So are you saying “it works”, but it is using your data? It actually will use your data to send a picture by text (on a non apple device) but the data will be reimbursed back to your data account.
I am not so sure it works that way. Friend sent me MMS and I had to turn data on but 300k was not reimbursed. Not a big deal but MMS will NOT go through WiFi as it requires DATA to be on.
04-22-2021 05:51 PM
No I am in Nova Scotia
04-22-2021 12:36 PM - edited 04-22-2021 12:38 PM
<edit>, okay now I see you are getting a failure message. I sometimes have this problem when I have a weak data signal though the number of bars shown doesn’t necessarily dictate that it is particularly weak. I find moving to a different location frequently works. You aren’t in Manitoba are you?
AE_Collector
04-22-2021 11:50 AM
Hi
Yes MMS is already turned on and cellular data is also turned on. When WIFI isn't available it uses Data
04-22-2021 11:46 AM
Go to Settings/Messages and turn on MMS. If there is no switch for it contact your carrier to have the feature provisioned on your account. Once it is on note that MMS requires cellular data, so if your only data connection is Wi-Fi you cannot send or receive MMS.
