Physical sim problem
LubnaAbid
Yesterday I was change my eSIM to physical sim and it was working fine but today it stop working. I removed e Sim but still it doesn’t work, what can I do?
@LubnaAbid
here's how you update your sim number...
hi @LubnaAbid
disable the esim, reboot phone and reset network settings on the phone
if same, then submit a ticket with CS Agent using Chatbot here:
             Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with ticket submission, you can submit  ticket by direct message:
Sansan
Did you update the new sim number in your account profile? That must be done. Then restart your phone if it doesn't work immediately.
