Phones and service
Gumpmom
I have had public for a few months with no issues. All of a sudden my phone won’t make or receive calls. Text is working fine so I have service. Just no calls.
11 REPLIES 11
mm80
@Gumpmom Putting sim in the other phone was to see if it was a phone or account issue. Putting it in the other phone didn't make it work in your current phone. That's coincidence.
Gumpmom
I removed the SIM card and tried it in another phone. It worked. Then when I put the SIM back it my phone it worked as well ?? Thanks for the replies.
mm80
@Gumpmom wrote:
$40 plan
Are you using iPhone? Text could be working because of iMessage on wifi. Does mobile data work?
Gumpmom
$40 plan
geopublic
@Gumpmom  Public Mobile uses 3G for calls so make sure your device was not switched to only use LTE.
Maybe it's a temporary network issue in your area.
benfatto
@Gumpmom The old $10 plan stops all calls in/out after 50 minutes.
srlawren
@Gumpmom wrote:
Tried that thanks. And removed and reinserted the SIM card
@Gumpmom what plan are you on?  does it include unlimited calling (typically $25 or more plans) or a limited amount ($15 plan, or the $10 plan of the past)?
dabr
@Gumpmom   What plan are you on?
Gumpmom
Triguy
Try rebooting your phone.  Also try making your phone lost then wait 5 minutes then make it found.
gpixel
@Gumpmom try restarting your device
can you login to your self serve and make sure the last 4 digits match the last 4 digits on your sim card.click on "change sim card"
if the sims don't match, your account may be in the process of a sim swap (fraud)
