10-17-2018 10:28 AM - edited 01-05-2022 02:10 AM
I was with Telus prepaid previous to public mobile. So I ported my number when activating my new service and I can’t get any income txts or phone calls. Ppl attempting to call me get a recording saying my number is not in service but I can make out bound calls.
10-17-2018 11:37 AM
Thank you very much and I ported the number last Friday. So I will attempt the suggestions you recommend. Fingers crossed it works
10-17-2018 11:15 AM
@NDesai wrote:
@mimmo wrote:@NDesai I thought it was only koodo prepaid that had issues.
I am pretty sure Telus Prepaid as well.
found the thread https://productioncommunity.publicmobile.ca/t5/Discussions/porting-telus-prepaid-and-chatr-to-PM/m-p...
but back to the orriginal question, since incoming calls go to" this number is not in service" to me implies stuck port and inactive telus account. unless port was successful and did not complete have seen this sistuation as well before.
10-17-2018 11:10 AM
10-17-2018 11:01 AM
10-17-2018 10:48 AM - edited 10-17-2018 10:50 AM
@Tatiana01 How long ago did you port your number to Public Mobile?
Is your Telus sim still active? If yes, looks like something went wrong with the porting process. Depending on this, you can either try again from your self-serve account or you can contact the moderator to complete the port.
EDIT: Since you are coming from Telus PREPAID, did you use the same email address on Public Mobile? If yes, this is a known issue, and you will ilkely need to contact the Moderator_Team.
10-17-2018 10:48 AM
Sounds like stuck port. Problem is you will probably need to activate your Telus line again to do the port. Ports can only be done on active lines.
