06-06-2017 05:35 PM - edited 01-05-2022 02:10 AM
I just changed my plan and topped up my account with the funds needed. and my account wasnt updated. now if i try and change the plan it will not allow me. can someone look into this please. thanks
Payment
06-07-2017 02:45 PM
Did you issue get resolved? Was it a glitch in the system?
06-06-2017 05:54 PM
Was your account expired? If so, plan changes on expired accounts can only be done by a moderator. Since you've already topped up your account, then the only thing you'll need to do is contact a moderator as @Someone_here mentioned, giving them your phone number and the details of the plan you want.
06-06-2017 05:38 PM
Hi @shaw146!
You'll need the assistance of a moderator to check this for you.
I suggest you send them a private message. Be sure to include your Public Mobile phone number and/or account number as well as a detailed description of your problem. Click here to know how contact them. They are available Mon-Thursday from 9am to 9pm and Friday-Sunday from 9am to 5:30pm (eastern time). They usually respond pretty fast to help requests!
I hope your problem will be solved quickly 🙂
