Phone show sos
Peterma196
For some reason my phone has stopped working and network shows sos. I have put my physical sim in anther phone and same issue
13 REPLIES 13
@Peterma196  Awesome we happy to hear it and that’s what I thought from the start
Peterma196
Thank you, they reprovioned my sim and all working well
@Peterma196  While waiting for support also if you have taken the SIM card out of the phone make sure it’s the right side up in the SIM card tray  sometimes this happens and easy to not notice
@Peterma196  They should reply with in the hour and ask you some verification questions to start before helping you . Just keep an eye on your community in box or use this link to it
Peterma196
Thanks I have done so
Peterma196
Thanks I have sent a message
@Peterma196
There maybe a provisional/backend issue with your SIM so contact a CS_Agent by private messaging so they can check and fix it at their end.
Contact them at:
Peterma196
No it is not a payment issue
@Peterma196
sounds like sim is gunny-bagged !  PM has esims available for $5, or get a new hard sim from Amazon for $5. Then change the sim number yourself in your account.
Priority
Did your credit card payment maybe bounce?
@Peterma196  You need to contact support to re provision the sim for you . Use this direct link to message support for help
send a  private message   To CS_Agents click
Peterma196
A year
hairbag1
@Peterma196
how long have you had your PM account ?
