Phone requirements
06-17-2019 11:12 AM - edited 01-05-2022 05:25 AM
06-22-2019 09:31 PM
Yes. I have an iPhone 5s and it worked very well with PM in the last 3 years. Then I got an iPhone 7 which also works perfectly with PM. So go ahead.
06-17-2019 11:51 AM - edited 06-17-2019 11:52 AM
@melitapaul,If you mean is it eligible or compatible you can use PM's phone checker by going to this link
06-17-2019 11:47 AM
It should work with PM as long as it is unlocked.
06-17-2019 11:25 AM
It should have said compatible not required sorry
06-17-2019 11:20 AM
@melitapaul wrote:Is a iPhone 5S a required phone?
What do you mean "required"? It should certainly be compatible as above. As for "required", you can use any phone that is unlocked and compatible with Telus/Bell.
06-17-2019 11:15 AM - edited 06-17-2019 11:18 AM
iPhone 5S should work with PM service.
I purchased an iPhone 5S from Koodo a few years back. Koodo and PM are on the same Telus network.
