Phone order
Nicecreek
I ordered a phone on Dec 7, got a confirmation, but never a tracking number...
it's been 2 weeks...
Where is my phone?
ThatPug
As noted by softech, you'll need to contact support.  I can however attest to the fact that they probably do have a tracking number for the package, just it may take a bit for them to get back to you.  You'll need to find the order number and provide that and a bit more information probably.
hairbag1
@Nicecreek
under normal circumstances, figure up to 4 weeks for delivery. Due to Xmas season, could be more. If you're in Vancouver, could be longer due to a bit of snow !!
@Nicecreek   you need to open ticket with PM support and ask them for status update.
since Chatbot has problem with CPO related ticket, please direct message them with your order number here:
