12-21-2022 01:51 PM
I got the text Dec. 4, 2022 offering free data and free minutes. I Replied as requested and received a text saying the data and minutes have been added to my account.
It does look like the data has been added, but not the 500 free minutes.
What happened?? How do I get this fixed??
Thanks,
Shirley
12-21-2022 02:47 PM
@tarsbo actually it likely still a cache issue on your desktop
try using Incognito mode when you are using your desktop (or even mobile) and it should show you the correct info
12-21-2022 02:45 PM
I've found the website to be very buggy on desktop. But for some reason, when I log on via my phone, everything is up to date. I'd recommend refreshing the sections as others have mentioned below. If this doesn't solve it, you should certainly open a ticket with CS_Agent! Good luck.
12-21-2022 02:12 PM
12-21-2022 02:10 PM
Public Mobile has web page cache issue so you might be looking at obsolete status. Click on little spinner refresh icons lower down. Try using different browser. Try Incognito/private mode. Clear browser’s cache. Try forced refresh. Use computer and not phone to log in.
12-21-2022 02:00 PM
This is what I got in my account. Try refresh and see if will show up. Also, go to the history and see if you accidentally used those minutes (not likely, but sometimes weird things happen).
Last but not least, if the things above don't work, file a ticket with SIMon.
12-21-2022 01:56 PM
First try to login in again with a different web browser, clear cache or incognito mode. There have been issues with this website showing the old "cached" version of your plan.
If you still don't see the add on, then you will need to contact customer service agent.
12-21-2022 01:55 PM - edited 12-21-2022 01:56 PM
Try logging into your account using a browser in incognito or private mode instead.
Try again
When you get into your account, click on the refresh button so you can see the latest information .
12-21-2022 01:54 PM
you will need to contact an agent
