03-03-2024
03:47 PM
03-03-2024
08:13 PM
computergeek541
I just switched to Public Mobile. I am uabale to receive SMS from Public Mobile to confirm that it's me. How long does a transfer of my phone number take? or I am doing something wrong.
03-03-2024 03:52 PM - edited 03-03-2024 03:56 PM
Hey there. There is a number you can call to get this porting issue resolved. I will send you a private message to your mailbox in the top right corner of this page or click on this link to direct access.
It should take less than 90 minutes. Did you leave your SIM card in from your other provider? If not, you will need to place it back in so you can get the porting text from them so you can say YES. You did nothing wrong. Sometimes ports get stuck. You can check this link to confirm your number can be ported.
Check Eligibility to Move (koodomobile.com)
Welcome to Public Mobile. Hope you got yourself a great plan. Maybe one of the newest Promo plans.
03-03-2024 03:49 PM - last edited Monday
HI @achrz
Did you get a text from the old carrier, did you reply Yes within 90 mins?
and can you receive inbound phone calls, especially from Non-Telus/Koodo/PM phone? If you cannot the port was not done
It could be an incomplete port. PM porting support team can help. I have sent you the porting support team number. Please check your Community inbox (https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage), check for the number and call.
And in case the poring team cannot help and ask you to submit ticket (or you rather submit ticket anyway),Please use the same Community login you are using now. (If you get stuck with the login or 2FA code, then use a different email address to create another Community account and submit the ticket with this new account): https://expert-messaging.publicmobile.ca/guest/chat/
Once you started the Chat, type "Submit Ticket", then "Connect Agent", and it will ask you to login to open ticket
(If unable to receive 2FA SMS, click "Didn't Receive Code" or "Resend Code" and Select "Send Email" or "Send Voice Message")
Remember CS_agent will reply within 2 to 4 hours. You will be notified via SMS/email or monitor here:
