04-05-2024
04:48 AM
04-05-2024
05:50 PM
computergeek541
I transferred my phone number from text now app but it does not seem to be working with public mobile unless it hasn’t been activated yet what can I do?
04-05-2024 07:51 AM
@scars613 will Send you the porting team . They can give status update on the port . Or re trigger it if needed . Check you in box for the phone number . And just in case here how to contact support incase they are needed also
submit ticket with support . using the chat bubble bottom right of screen
If that doesn’t work you can always send private message to support .
send a private message To CS_Agents
04-05-2024 07:50 AM - edited 04-05-2024 07:51 AM
can you please clarify what you mean? If your services are not fully working, try rebooting your device, and resetting network connections.
If you are unable to login using the Public Mobile app, try using the website to login. (Or vice versa)
You can also try clearing the systems (& app) cookies, cache and data.
