5 hours ago
- last edited
5 hours ago
computergeek541
Hi, when I transfer my old number that has a QC area Code (438) to my new plan at Public Mobile in BC, can I keep my old number with the old QC area code?
Thank you
5 hours ago
HI @JuliMax
in PM, it does not matter your number and your location. So, you can have a QC number ported in to your BC account
But sometimes, it is the number itself that has some limitation to be ported, check here to confirm
https://secure.koodomobile.com/checktransfereligibilityparrot/checkSingle.do
5 hours ago
Thank you!
5 hours ago
@JuliMax I don't think it will work and will likely cause problems. When moving to another province you should using the area codes associated with the province
5 hours ago - last edited 5 hours ago
yes you can,. But remember PM charges tax by the area code of the phone number. So, keeping a QC number means you will be charged QC rate and not BC rate
