yesterday - last edited yesterday by computergeek541
Hey guys,
has any of you not been able to use your data? i haven't been able to use it for the past year and tried several times to contact customer support to no avail. They are also very lousy at customer service, removed my old rewards without even informing me or compenstating me. I heard some people got compenstated. Any advice on how to approach this aggravating situation with their extremely unhelpful team?
yesterday
why and how you stand a year with no data and only decide to get it cleared up now?
what phone you have? did you try Reset All Networks? or maybe you tried on another phone?
yesterday
@TXx041 that's strange that you don't have data for such a long time?
Are you still able to make and receive calls, texts?
Is your account up to date?
To fix the data issue you can try to reset your phone networks.
The compensation that everyone received if they were switched from the loyal rewards program was extra data based on your current plan that was given in April with a 150-day expiration date.
If you were on the $15 plan you got 5GB of data.
There were emails and texts messages sent from Public Mobile on March 6 advising of the upcoming changes.
You can contact them here.
them https://widget.telus.tiia.ai/publicmobile/publicmobile.html
Or
yesterday
Data should be useable, unless your device needs to have it's APN settings reset.
You may also wish to try rebooting device and resetting network connections. If you can, try the SIM card in another device for awhile to see if data works on the other device.
